Stormin08
Well-known member
interesting... I love the spring rate. and that is doubled down by the 24 TB i also did for a co worker...he has the 2.0 with a 550 spring and rides amazing. although I have adjustment capabilities, the 2.0 rides great for a static replacement.
you over height is lower ? not sure I am interpreting that part correctly, visually the lower arm does seem to have more rise at the BJ than the current DK arms
i have nearly a 1/2" thick spacer on the lower arm now, just playing with heights...so my front is sitting at about 2.25" over stock...I have the mini pak installed, with NO spacers...just the stock block and 3 Deaver leaf's, it is still higher that I like for stance.
side note...i see sway bar ends hanging....you still run the front bar ? i get a lot of flack for it...that always goes first. I let the shock handle that part as well. that come from my old 3/4" Dodge days with the likes of Carli and Thuren...
